ArcGIS.Desktop.Mapping Namespace / SurfaceZsResult Class
Members Example
    Defines the result of calling Map.GetZsFromSurfaceAsync()
    Object Model
    SurfaceZsResult ClassGeometry Class
    Syntax
    public sealed class SurfaceZsResult
    Public NotInheritable Class SurfaceZsResult
    Example
    Get Z values from the default ground surface
      var surfaceZResult = await QueuedTask.Run(async () =>
        // Get the center of the map's full extent
        MapPoint mapPoint = map.CalculateFullExtent().Center;
        //Pass any Geometry type to GetZsFromSurfaceAsync
        return await map.GetZsFromSurfaceAsync(mapPoint);
      if (surfaceZResult.Status == SurfaceZsResultStatus.Ok)
        // cast to a mapPoint
        var mapPointZ = surfaceZResult.Geometry as MapPoint;
        var z = mapPointZ.Z;
    Get Z values from a specific surface
        var eleLayer = map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
        //Ensure the feature layer is a line layer and is Z aware
        var selectedFeatures = featureLayer.GetSelection();
        var rowCursor = selectedFeatures.Search();
        while (rowCursor.MoveNext())
          var feature = rowCursor.Current as Feature;
          var polyline = feature.GetShape() as Polyline;
          var zResult = await map.GetZsFromSurfaceAsync(polyline, eleLayer);
          if (zResult.Status == SurfaceZsResultStatus.Ok)
            var polylineZ = zResult.Geometry as Polyline;
            // process the polylineZ
            // For example, you can iterate through the points and access their Z values
    Get Z values from a layer
      await QueuedTask.Run(() =>
        TinLayer tinLayer = map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
        MapPoint mapPoint = map.CalculateFullExtent().Center; //Any Map Point
        Polyline polyline = PolylineBuilderEx.CreatePolyline(mapView.Extent); //Any Polyline
        if (tinLayer.CanGetZs())
          // get z value for a mapPoint
          var zResult = tinLayer.GetZs(mapPoint);
            var mapPointZ = zResult.Geometry as MapPoint;
          // get z values for a polyline
          zResult = tinLayer.GetZs(polyline);
    Get Z values from a TIN Layer
            // cast to a Polyline
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.SurfaceZsResult
    Requirements
