ArcGIS.Desktop.Mapping Namespace / StandaloneTable Class / CanSetTime Method
The time parameters to set.
    CanSetTime Method (StandaloneTable)
    Gets if the mapMember supports time filtering and if the specified time parameters are valid. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides Function CanSetTime( _
       ByVal timeParams As TimeParameters _
    ) As Boolean
    public override bool CanSetTime(
       TimeParameters timeParams
    Parameters
    timeParams
    Return Value
    True if the mapMember supports time filtering and the timeParams are valid. False otherwise.
    Exceptions
    ExceptionDescription
    Remarks
    You should use this method before calling the SetTime method.
    Standalone tables do not support TimeParameters.StepInterval or TimeIntervalType when only start or end dates are specified.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
