| | Name | Description |
 | CanClearTime |
Gets if the mapMember supports time filtering and can clear the time filter. Clearing the time filter ensures that
data is always shown.
This method must be called on the MCT. Use QueuedTask.Run.
(Inherited from ArcGIS.Desktop.Mapping.MapMember) |
 | CanEditData | Returns true if the data can be edited. |
 | CanGetTime |
Gets if the mapMember supports time filtering.
 | CanReplaceDataSource |
Check if the standalone table's data source can be replace with this table.
 | CanSetTime | Overridden.
Gets if the mapMember supports time filtering and if the specified time parameters are valid.
 | ClearSelection |
Clears the current selection.
 | ClearTime |
Clears the time filter for the mapMember. Clearing the time filter ensures that
 | ExportPopupConfiguration |
Exports the MapMember's current popup configuration to a .pop file.
 | FindAndReplaceWorkspacePath |
Performs a find and replace of workspace path for the table.
 | GetCanEditMetadata | Overridden.
Gets whether the StandaloneTable metadata can be edited or not. This method must be called on the MCT.
Use QueuedTask.Run.
 | GetDataConnection |
Gets a CIMDataConnection value object.
 | GetDataTimeExtent |
Gets the time extent of the data for the specified fieldName - that is the minimum and maximum dates present in the data.
 | GetDataTimeIntervals |
Gets the set of time intervals for the specified field name present in the data.
 | GetDefinition |
Returns the standalone table's CIM definition.
 | GetDisplayExpressions |
Gets the display expressions of the given set of objects.
 | GetFieldDescriptions |
Returns fields of the standalone table including joined fields, if any.
 | GetMetadata | Overridden.
Gets the StandaloneTable metadata. This method must be called on the MCT.
Use QueuedTask.Run.
 | GetPath |
Gets the path of the dataset underneath the MapMember as a Uri.
 | GetSelection |
Gets the current selection of the table.
 | GetTable |
Returns the underlying table.
 | GetTime |
Gets the current time parameters for the mapMember.
 | GetUseSourceMetadata |
Gets whether or not the MapMember stores its own metadata or uses metadata
retrieved from its source. This method must be called on the MCT.
Use QueuedTask.Run.
 | ImportPopupConfiguration |
Imports a .pop file and sets the popup configuration for the MapMember.
 | InsertDefinitionQueries | Insert a list of DefinitionQuery. This method must be called on the MCT. Use QueuedTask.Run. |
 | InsertDefinitionQuery | Inserts a DefinitionQuery. If is true, makes it the active definition query. This method must be called on the MCT. Use QueuedTask.Run. |
 | IsTimeSupported |
Gets if time is supported for this mapMember. This method must be called on the MCT. Use QueuedTask.Run.
 | IsValidDefinitionQuery | Overloaded. |
 | RemoveActiveDefinitionQuery |
Removes the active definition query. This method must be called on the MCT. Use QueuedTask.Run.
 | RemoveAllDefinitionQueries |
Remove all definition queries. This method must be called on the MCT. Use QueuedTask.Run.
 | RemoveDefinitionQueries |
Removes the definition queries specified by the list of names. This method must be called on the MCT. Use QueuedTask.Run.
 | RemoveDefinitionQuery |
Removes the definition query at the specified index. This method must be called on the MCT. Use QueuedTask.Run.
 | ReplaceDataSource |
Replace the standalone table's data source.
 | Search |
Executes a query to the underlying data source and returns rows matching the search criteria.
 | SearchEx |
 | Select |
Selects rows based upon the specified criteria and combination method.
 | SetActiveDefinitionQuery | Sets the definition query matching the specified to be the active definition query. This method must be called on the MCT. Use QueuedTask.Run. |
 | SetDataConnection |
Updates a MapMember's data source.
 | SetDefinition |
Updates the standalone table's CIM definition.
 | SetDefinitionQuery |
Sets the where clause of the active definition query.
 | SetDisplayExpressionInfo |
Sets the display expression info with an arcade expression that will be used to identify features or rows. This method must be called on the MCT. Use QueuedTask.Run.
 | SetDisplayField |
Sets the name of the attribute field that will be used to identify features or rows. This method must be called on the MCT. Use QueuedTask.Run.
 | SetEditable |
Enables or disables editing on a standalone table.
 | SetFieldDescriptions |
Applies updates to the editable properties of fields.
 | SetMetadata | Overridden.
Sets the StandaloneTable metadata. This method must be called on the MCT.
Use QueuedTask.Run.
 | SetName |
Sets the display name for the MapMember.
 | SetSelectable |
Toggles the selectability.
 | SetSelection |
Sets the current selection of the table.
 | SetSelectRelatedData |
Toggles the SelectRelatedData of a MapMember.
 | SetShowPopups |
Toggles enabling pop-ups for the layer.
 | SetTime |
Sets the specified time parameters for the mapMember.
 | SetUseSourceMetadata |
Sets whether or not the MapMember will use its own metadata or the metadata
from its underyling source (if it has one). This method must be called on the MCT. Use QueuedTask.Run.
 | ToString |
Returns the display name of the MapMember.
