ArcGIS.Desktop.Mapping Namespace / StandaloneTable Class / SetDisplayExpressionInfo Method
Your custom expression info.
    SetDisplayExpressionInfo Method (StandaloneTable)
    Sets the display expression info with an arcade expression that will be used to identify features or rows. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetDisplayExpressionInfo(
       CIMExpressionInfo displayExpressionInfo
    Public Sub SetDisplayExpressionInfo( _
       ByVal displayExpressionInfo As CIMExpressionInfo _
    Parameters
    Exceptions
    ExceptionDescription
    Remarks
    The display expression is also used in map tips, popups, editing tools and selection chip.
    Requirements
    ArcGIS Pro version: 3.6 or higher.
