ArcGIS.Desktop.Mapping Namespace / StandaloneTable Class / Select Method
A query filter.
A combination method.
A time filter only works if the table is time enabled.
A range filter only works if the table is range enabled.
A floor filter filter only works if the layer has a defined floor field.
    Select Method (StandaloneTable)
    Selects rows based upon the specified criteria and combination method. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function Select( _
       Optional ByVal queryFilter As QueryFilter, _
       Optional ByVal method As SelectionCombinationMethod, _
       Optional ByVal time As TimeRange, _
       Optional ByVal range As RangeExtent, _
       Optional ByVal floor As CIMFloorFilterSettings _
    ) As Selection
    Parameters
    queryFilter
    A query filter.
    method
    time
    range
    floor
    Return Value
    A selection set.
    Exceptions
    ExceptionDescription
    Remarks
    Rows in the standalone table view are highlighted as a result of this method call.
    If there is a definition query set on the standalone table, the Select() method will automatically work on the subset of rows in the standalone table that meet the definition criteria. You specify an additional query that will be applied after the standalone table's definition query by passing valid QueryFilter object for the QueryFilter parameter.
    If the standalone table has any joins, this Select() method takes that into account.
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.Selection in either a using statement or a finally block.
    Requirements
