ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / AutoGenerateTemplates Method
The mapMember to generate templates for.
(Optional) Remove existing templates and regenerate. (default value = false)
    Generate feature templates for a layer or standalone-table. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function AutoGenerateTemplates( _
       ByVal mapMember As MapMember, _
       Optional ByVal forceCreate As Boolean _
    ) As Boolean
    public static bool AutoGenerateTemplates(
       MapMember mapMember,
       bool forceCreate
    Parameters
    mapMember
    forceCreate
    Return Value
    Boolean. True if templates were generated.
    Remarks
    This method attempts to generate feature templates on a layer or standalone-table. If ArcGIS.Core.CIM.CIMBasicFeatureLayer.AutoGenerateFeatureTemplates flag is true, the templates are generated from the renderer. When false the templates are not regenerated unless forceCreate is specified.
    Requirements
