await QueuedTask.Run(() => { var templateName = "Distribution"; // name of the template to update var toolDamlPlugInID = "esri_editing_SketchTwoPointLineTool"; // DAML ID of the tool to set as default var toolContentGUID = "e2096d13-b437-4bc1-94ea-4494c3260f72"; // Example GUID, replace with actual GUID from DAML // retrieve the edit template form the layer by name var template = featureLayer?.GetTemplate(templateName) as EditingTemplate; // get the definition of the layer var layerDef = featureLayer?.GetDefinition() as CIMFeatureLayer; if (template == null || layerDef == null) return; if (template.DefaultToolID != toolDamlPlugInID) { bool updateLayerDef = false; if (layerDef.AutoGenerateFeatureTemplates) { layerDef.AutoGenerateFeatureTemplates = false; updateLayerDef = true; } // retrieve the CIM edit template definition var templateDef = template.GetDefinition(); // assign the GUID from the tool DAML definition, for example // <tool id="TestConstructionTool_SampleSDKTool" categoryRefID="esri_editing_construction_polyline" ….> // <tooltip heading="">Tooltip text<disabledText /></tooltip> // <content guid="e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea" /> // </tool> // then the toolContentGUID would be "e58239b3-9c69-49e5-ad4d-bb2ba29ff3ea" //templateDef.ToolProgID = toolContentGUID; templateDef.DefaultToolGUID = toolContentGUID; // set the definition back to template.SetDefinition(templateDef); // update the layer definition too if (updateLayerDef) featureLayer.SetDefinition(layerDef); } });
