ArcGIS.Desktop.Mapping Namespace / StandaloneTable Class / Search Method
A query filter
A time filter only works if the table is time enabled.
A range filter only works if the table is range enabled.
A floor filter filter only works if the layer has a defined floor field.
    Search Method (StandaloneTable)
    Executes a query to the underlying data source and returns rows matching the search criteria. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function Search( _
       Optional ByVal queryFilter As QueryFilter, _
       Optional ByVal time As TimeRange, _
       Optional ByVal range As RangeExtent, _
       Optional ByVal floor As CIMFloorFilterSettings _
    ) As RowCursor
    Parameters
    queryFilter
    A query filter
    time
    range
    floor
    Return Value
    A RowCursor allows access to the matched rows.
    Exceptions
    ExceptionDescription
    Remarks
    If there is a definition query set on the standalone table, the Search() method will automatically work on the subset of rows in the standalone table that meet the definition criteria. You specify an additional query that will be applied after the standalone table's definition query by passing valid QueryFilter object for the QueryFilter parameter.
    If the standalone table has any joins, this Search() method takes that into account.
    You can use the cursor returned by Search to update rows.
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.RowCursor in either a using statement or a finally block.
    Requirements
