ArcGIS.Desktop.Mapping Namespace / StandaloneTable Class / GetSelection Method
    GetSelection Method (StandaloneTable)
    Gets the current selection of the table. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Selection GetSelection()
    Public Function GetSelection() As Selection
    Exceptions
    ExceptionDescription
    Remarks
    This method only works with ObjectID-based selections.
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.Selection in either a using statement or a finally block.
    Requirements
