ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / Inspect Method
A mapMember
The oid of the row.
    Inspect Method
    Loads a row into a new inspector instance. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function Inspect( _
       ByVal mapMember As MapMember, _
       ByVal oid As Long _
    ) As Inspector
    public static Inspector Inspect(
       MapMember mapMember,
       long oid
    Parameters
    mapMember
    A mapMember
    oid
    The oid of the row.
    Return Value
    An ArcGIS.Desktop.Editing.Attributes.Inspector loaded with the specified row.
    Exceptions
    ExceptionDescription
    Requirements
