ArcGIS.Desktop.Editing.Attributes Namespace / Inspector Class
Members Example
    Inspector Class
    Provides access to the attribute values on features and rows.
    Syntax
    Remarks
    This class is primarily used to get or set the attribute values on features or rows. Additionally it provides some meta information.
    To get or set attribute values, first load a feature or row into the class then use the class properties or attribute index/name.
    You can also use the Inspector class to obtain schema information about a mapMember. Use the LoadSchema(MapMember) or LoadSchemaAsync(MapMember) methods to obtain schema information.
    Example
    Inspector.AddValidate
    // Adds a custom validation rule to the "Mineral" field of the specified feature layer.
    await QueuedTask.Run(() =>
      var insp = new Inspector();
      insp.LoadSchema(featureLayer);
      var attrib = insp.Where(a => a.FieldName == "Mineral").First();
      attrib.AddValidate(() =>
        if (attrib.CurrentValue.ToString() == "Salt")
          return [];
        else return [ArcGIS.Desktop.Editing.Attributes.Attribute.ValidationError.Create("Error", Severity.Low)];
    Read and Write blob fields with the attribute inspector
      // get selected feature into inspector
      var selectedFeatures = activeMap.GetSelection();
      insp.Load(selectedFeatures.ToDictionary().Keys.First(), selectedFeatures.ToDictionary().Values.First());
      // read a blob field and save to a file
      var msw = new MemoryStream();
      msw = insp["BlobField"] as MemoryStream;
      using (FileStream file = new(@"d:\temp\blob.jpg", FileMode.Create, FileAccess.Write))
        msw.WriteTo(file);
      // read file into memory stream
      var msr = new MemoryStream();
      using (FileStream file = new(@"d:\images\Hydrant.jpg", FileMode.Open, FileAccess.Read))
        file.CopyTo(msr);
      //put the memory stream in the blob field and save to feature
      var op = new EditOperation() { Name = "Blob Inspector" };
      insp["Blobfield"] = msr;
      op.Modify(insp);
      if (!op.IsEmpty)
        var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Editing.Attributes.Inspector
    Requirements
