| Name | Description | |
![]() | Inspector Constructor | Create a new instance of the inspector class. |
The following tables list the members exposed by Inspector.
![]() | AllowEditing | Gets or sets a flag to prevent users from modifying it's fields value. |
![]() | GeometryAttribute | Gets the geometry (shape) attribute. |
![]() | HasAnnotationAttributes | Gets a Boolean value indicating whether this inspector has any annotation features. |
![]() | HasAttributes | Gets a Boolean value indicating whether this inspector has any attributes. |
![]() | HasDimensionAttributes | Gets a boolean value indicating whther this inspector has any dimension features. |
![]() | HasGeometry | Gets a Boolean value indicating whether this inspector has any geometry. It will return false when feature inspector has two or more features or for features belonging to Stand Alone tables. |
![]() | HasValidAttributes | Gets a Boolean indicating if all of the attributes are valid. Returns false if any attributes are not valid. |
![]() | HasValidEdits | Gets a Boolean indicating if all of the edited attributes are valid. Returns false if any edited attributes are not valid, null if no edits or IsFeature is false. |
![]() | IsDirty | Gets a Boolean indicating whether any attribute in the list of Attributes is modified. |
![]() | IsEditable | Gets a Boolean indicating if the feature/row is editable. |
![]() | Item | Overloaded. Returns the current value of attribute. Takes in the index of attribute as the parameter. |
![]() | MapMember | Gets the mapMember of the features. |
![]() | ObjectID | Gets the ObjectID for the feature loaded into an inspector. |
![]() | ObjectIDAttribute | Gets the attribute for the ObjectID field. |
![]() | OIDSet | Gets the OID's of features loaded into an inspector. |
![]() | Shape | Gets or sets the geometry (shape) of objects within the inspector. |
![]() | SubtypeAttribute | Gets the SubtypeAttribute. |
![]() | AddAttributeAsync | Overloaded. Add an attribute to the feature inspector. |
![]() | Apply | Apply the attribute changes. Writing them back to the database in an Edit Operation. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | ApplyAsync | Apply the attribute changes. Writing them back to the database in an Edit Operation. |
![]() | Cancel | Cancel the Attribute changes, reverting back to the database's state. |
![]() | ChangeSubtype | Change the subtype of the features. |
![]() | Clear | Clears or empties the inspector. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | ClearAsync | Clears or empties the inspector. |
![]() | CreateEmbeddableControl | Creates the embeddable user control associated with this instance of the inspector. |
![]() | GetAnnotationProperties | Gets the ArcGIS.Desktop.Editing.AnnotationProperties for annotation features in the inspector. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | GetDimensionProperties | Gets the ArcGIS.Desktop.Editing.DimensionProperties for dimension features in the inspector. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | GetEnumerator | Enables enumeration through attributes on the inspector. |
![]() | Load | Overloaded. Load objects into the inspector. |
![]() | LoadAsync | Overloaded. Load objects into the inspector. |
![]() | LoadSchema | Overloaded. Load the schema of an object into the inspector. |
![]() | LoadSchemaAsync | Load the schema of a mapMember into the inspector. |
![]() | SetAnnotationProperties | Sets annotation properties on annotation features within the inspector. This method must be called on the MCT. Uses QueuedTask.Run. |
![]() | SetDimensionProperties | Sets dimension properties on dimension features in the inspector. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | TryGetValue | Gets the current value of the attribute specified by fieldName. |
![]() | TrySetValue | Sets the value of the attribute specified by the fieldName. |
![]() | TrySetValues | Sets the value of the attributes specified by the dictionary of (fieldName, value) pairs. |
![]() | NotifyPropertyChanged | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | SetProperty | Overloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase) |
