// Creates a new annotation template for the specified annotation layer.
await QueuedTask.Run(() =>
Inspector insp = null;
// get the anno feature class
var fc = annotationLayer.GetFeatureClass() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClass;
// get the feature class CIM definition which contains the labels, symbols
var cimDefinition = fc.GetDefinition() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClassDefinition;
var labels = cimDefinition.GetLabelClassCollection();
var symbols = cimDefinition.GetSymbolCollection();
// make sure there are labels, symbols
if (labels.Count == 0 || symbols.Count == 0)
return;
// find the label class required
// typically you would use a subtype name or some other characteristic
// in this case lets just use the first one
var label = labels[0];
// each label has a textSymbol
// the symbolName *should* be the symbolID to be used
var symbolName = label.TextSymbol.SymbolName;
int symbolID = -1;
if (!int.TryParse(symbolName, out symbolID))
// int.TryParse fails - attempt to find the symbolName in the symbol collection
foreach (var symbol in symbols)
if (symbol.Name == symbolName)
symbolID = symbol.ID;
break;
// no symbol?
if (symbolID == -1)
return;
// load the schema
insp = new Inspector();
insp.LoadSchema(annotationLayer);
// ok to assign these fields using the inspector[fieldName] methodology
// these fields are guaranteed to exist in the annotation schema
insp["AnnotationClassID"] = label.ID;
insp["SymbolID"] = symbolID;
// set up some additional annotation properties
AnnotationProperties annoProperties = insp.GetAnnotationProperties();
annoProperties.FontSize = 36;
annoProperties.TextString = "My Annotation feature";
annoProperties.VerticalAlignment = VerticalAlignment.Top;
annoProperties.HorizontalAlignment = HorizontalAlignment.Justify;
insp.SetAnnotationProperties(annoProperties);
var tags = new[] { "Annotation", "tag1", "tag2" };
// use daml-id rather than guid
string defaultTool = "esri_editing_SketchStraightAnnoTool";
// tool filter is the tools to filter OUT
var toolFilter = new[] { "esri_editing_SketchCurvedAnnoTool" };
// create a new template
var newTemplate = annotationLayer.CreateTemplate("new annotation template", "description", insp, defaultTool, tags, toolFilter);
