ArcGIS.Desktop.Editing.Attributes Namespace / Inspector Class / ChangeSubtype(Int32,Boolean) Method
An integer value indicating the desired code
A Boolean value indicating whether the default attributes for the feature need to be changed to those defined by the proposed subtype
    Change the subtype of the features.
    Syntax
    public bool ChangeSubtype(
       int proposedCode,
       bool propogate
    Public Function ChangeSubtype( _
       ByVal proposedCode As Integer, _
       Optional ByVal propogate As Boolean _
    ) As Boolean
    Parameters
    proposedCode
    propogate
    Return Value
    A boolean indicating whether subtype change was applied.
    Requirements
