public AnnotationProperties GetAnnotationProperties()
Public Function GetAnnotationProperties() As AnnotationProperties
Return Value
The annotation properties for the features currently loaded in the inspector.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
// Creates a new annotation template for the specified annotation layer. await QueuedTask.Run(() => { Inspector insp = null; // get the anno feature class var fc = annotationLayer.GetFeatureClass() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClass; // get the feature class CIM definition which contains the labels, symbols var cimDefinition = fc.GetDefinition() as ArcGIS.Core.Data.Mapping.AnnotationFeatureClassDefinition; var labels = cimDefinition.GetLabelClassCollection(); var symbols = cimDefinition.GetSymbolCollection(); // make sure there are labels, symbols if (labels.Count == 0 || symbols.Count == 0) { return; } // find the label class required // typically you would use a subtype name or some other characteristic // in this case lets just use the first one var label = labels[0]; // each label has a textSymbol // the symbolName *should* be the symbolID to be used var symbolName = label.TextSymbol.SymbolName; int symbolID = -1; if (!int.TryParse(symbolName, out symbolID)) { // int.TryParse fails - attempt to find the symbolName in the symbol collection foreach (var symbol in symbols) { if (symbol.Name == symbolName) { symbolID = symbol.ID; break; } } } // no symbol? if (symbolID == -1) { return; } // load the schema insp = new Inspector(); insp.LoadSchema(annotationLayer); // ok to assign these fields using the inspector[fieldName] methodology // these fields are guaranteed to exist in the annotation schema insp["AnnotationClassID"] = label.ID; insp["SymbolID"] = symbolID; // set up some additional annotation properties AnnotationProperties annoProperties = insp.GetAnnotationProperties(); annoProperties.FontSize = 36; annoProperties.TextString = "My Annotation feature"; annoProperties.VerticalAlignment = VerticalAlignment.Top; annoProperties.HorizontalAlignment = HorizontalAlignment.Justify; insp.SetAnnotationProperties(annoProperties); var tags = new[] { "Annotation", "tag1", "tag2" }; // use daml-id rather than guid string defaultTool = "esri_editing_SketchStraightAnnoTool"; // tool filter is the tools to filter OUT var toolFilter = new[] { "esri_editing_SketchCurvedAnnoTool" }; // create a new template var newTemplate = annotationLayer.CreateTemplate("new annotation template", "description", insp, defaultTool, tags, toolFilter); });
await QueuedTask.Run(() => { // annotationLayer is ~your~ Annotation layer... // annotationPoint is ~your~ Annotation's location geometry ... var op = new EditOperation(); // Use the inspector var insp = new Inspector(); insp.LoadSchema(annotationLayer); // get the annotation properties from the inspector AnnotationProperties annoProperties = insp.GetAnnotationProperties(); // change the annotation text annoProperties.TextString = DateTime.Now.ToLongTimeString(); // change font color to green annoProperties.Color = ColorFactory.Instance.GreenRGB; // change the horizontal alignment annoProperties.HorizontalAlignment = HorizontalAlignment.Center; annoProperties.Shape = annotationPoint; // set the annotation properties back on the inspector insp.SetAnnotationProperties(annoProperties); // create the annotation op.Create(annotationLayer, insp); if (!op.IsEmpty) { var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
// Updates the text of an annotation feature in the specified annotation layer. await QueuedTask.Run(() => { // annotationLayer is ~your~ Annotation layer... // use the inspector methodology var insp = new Inspector(); insp.Load(annotationLayer, objectId); // get the annotation properties AnnotationProperties annoProperties = insp.GetAnnotationProperties(); // set the attribute annoProperties.TextString = annotationText; // assign the annotation properties back to the inspector insp.SetAnnotationProperties(annoProperties); //create and execute the edit operation EditOperation op = new EditOperation(); op.Name = "Update annotation"; op.Modify(insp); if (!op.IsEmpty) { var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
// Modifies the geometry of an annotation feature in the specified annotation layer. await QueuedTask.Run(() => { //Don't use 'Shape'....Shape is the bounding box of the annotation text. This is NOT what you want... // //var insp = new Inspector(); //insp.Load(annotationLayer, objectId); //var shape = insp["SHAPE"] as Polygon; //...wrong shape... //Instead, we must use the AnnotationProperties //annotationLayer is ~your~ Annotation layer var insp = new Inspector(); insp.Load(annotationLayer, objectId); AnnotationProperties annoProperties = insp.GetAnnotationProperties(); var shape = annoProperties.Shape; if (shape.GeometryType != GeometryType.GeometryBag) { var newGeometry = GeometryEngine.Instance.Move(shape, 10, 10); annoProperties.Shape = newGeometry; insp.SetAnnotationProperties(annoProperties); EditOperation op = new EditOperation { Name = "Change annotation angle" }; op.Modify(insp); if (!op.IsEmpty) { var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } } });
// Modifies the text graphic of a selected annotation feature in the specified annotation layer. await QueuedTask.Run(() => { var selection = annotationLayer.GetSelection(); if (selection.GetCount() == 0) { return; } // use the first selected feature var insp = new Inspector(); insp.Load(annotationLayer, selection.GetObjectIDs().FirstOrDefault()); // getAnnoProperties should return null if not an annotation feature AnnotationProperties annoProperties = insp.GetAnnotationProperties(); // get the textGraphic CIMTextGraphic textGraphic = annoProperties.TextGraphic; // change text textGraphic.Text = "Hello world"; // set x,y offset via the symbol var symbol = textGraphic.Symbol.Symbol; var textSymbol = symbol as CIMTextSymbol; textSymbol.OffsetX = 2; textSymbol.OffsetY = 3; textSymbol.HorizontalAlignment = HorizontalAlignment.Center; // load the updated textGraphic annoProperties.LoadFromTextGraphic(textGraphic); // assign the annotation properties back insp.SetAnnotationProperties(annoProperties); EditOperation op = new EditOperation { Name = "modify symbol" }; op.Modify(insp); if (!op.IsEmpty) { bool result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
