ArcGIS.Desktop.Editing.Attributes Namespace / Inspector Class / TrySetValue Method
A string value to search for a desired attribute field name. This search is case insensitive.
The value to apply to the attribute.
Example
    TrySetValue Method
    Sets the value of the attribute specified by the fieldName.
    Syntax
    public bool TrySetValue(
       string fieldName,
       object value
    Public Function TrySetValue( _
       ByVal fieldName As String, _
       ByVal value As Object _
    ) As Boolean
    Parameters
    fieldName
    value
    Return Value
    True if the inspector contains an attribute with the specified fieldName. False otherwise.
    Example
    Adds a custom validation rule to the "Mineral" field of the specified feature layer.
    await QueuedTask.Run(() =>
      var insp = new Inspector();
      insp.LoadSchema(featureLayer);
      bool success = insp.TrySetValue("mineral", "Salt");
      object result = null;
      success = insp.TryGetValue("mineral", out result);
      if (result != null && success)
        MessageBox.Show($"Successfully stored and retrieved the value of field 'Mineral': {result.ToString()}");
      var attrib = insp.Where(a => a.FieldName == "Mineral").First();
      attrib.AddValidate(() =>
        if (attrib.CurrentValue.ToString() == "Salt")
          return [];
        else
          return [ArcGIS.Desktop.Editing.Attributes.Attribute.ValidationError.Create("Error", Severity.Low)];
    Requirements
    ArcGIS Pro version: 3.8 or higher.
