ArcGIS.Desktop.Editing.Attributes Namespace / Inspector Class / ApplyAsync Method
Example
    ApplyAsync Method (Inspector)
    Apply the attribute changes. Writing them back to the database in an Edit Operation.
    Syntax
    public Task<bool> ApplyAsync()
    Public Function ApplyAsync() As Task(Of Boolean)
    Return Value
    A Task returning a Boolean indicating whether the value was applied to the database.
    Example
    Load map selection into Inspector and Change Attributes
    // Updates the "Description" attribute of the selected features in the specified selection set.
      // get the first layer and its corresponding selected feature OIDs
      var firstSelectionSet = selectedFeatures.ToDictionary().First();
      // create an instance of the inspector class
      var inspector = new Inspector();
      // load the selected features into the inspector using a list of object IDs
      await inspector.LoadAsync(firstSelectionSet.Key, firstSelectionSet.Value);
      // assign the new attribute value to the field "Description"
      // if more than one features are loaded, the change applies to all features
      inspector["Description"] = "The new value.";
      // apply the changes as an edit operation
      await inspector.ApplyAsync();
    Requirements
