ArcGIS.Desktop.Mapping Namespace / StandaloneTable Class / GetCanEditMetadata Method
    GetCanEditMetadata Method (StandaloneTable)
    Gets whether the StandaloneTable metadata can be edited or not. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public override bool GetCanEditMetadata()
    Public Overrides Function GetCanEditMetadata() As Boolean
    Return Value
    True if the metadata is editable
    Exceptions
    ExceptionDescription
    Remarks
    StandaloneTable metadata is typically editable unless the StandaloneTable is using an underlying source for metadata or the .aprx is not editable
    Requirements
