ArcGIS.Desktop.Mapping Namespace / TopologyLayer Class / GetTopology Method
Example
    GetTopology Method
    Gets the topology dataset associated with the layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Topology GetTopology()
    Public Function GetTopology() As Topology
    Return Value
    The topology dataset associated with the layer.
    Exceptions
    ExceptionDescription
    Example
    Create Topology Layer using Topology dataset
      //Get the Topology of another Topology layer
      var existingTopology = map.GetLayersAsFlattenedList().OfType<TopologyLayer>().FirstOrDefault();
      if (existingTopology != null)
        await QueuedTask.Run(() =>
          var topology = existingTopology.GetTopology();
          //Configure the settings for a new Catalog layer using the CatalogDataset of an existing layer
          var topologyLyrParams = new TopologyLayerCreationParams(topology);
          topologyLyrParams.Name = "NewTopologyLayerFromAnotherTopologyLayer";
          topologyLyrParams.AddAssociatedLayers = true;
          LayerFactory.Instance.CreateLayer<TopologyLayer>(topologyLyrParams, map);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
