ArcGIS.Core.Data Namespace / Datastore Class / GetConnector Method
Example
    GetConnector Method (Datastore)
    Gets the Connector associated with the currently opened data store. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public MustOverride Function GetConnector() As Connector
    public abstract Connector GetConnector()
    Return Value
    The Connector associated with the currently opened data store.
    Exceptions
    ExceptionDescription
    No valid data store has been opened prior to invoking this operation.
    A geodatabase-related exception has occurred.
    Example
    Get the Data Connection Properties from a Feature Service
      await QueuedTask.Run(() =>
        Layer selectedLayer = MapView.Active.GetSelectedLayers()[0];
        if (selectedLayer is FeatureLayer)
          FeatureLayer featureLayer = selectedLayer as FeatureLayer;
          using (Table table = featureLayer.GetTable())
          using (Datastore datastore = table.GetDatastore())
            ServiceConnectionProperties serviceConnectionProperties = datastore.GetConnector() as ServiceConnectionProperties;
            if (serviceConnectionProperties == null)
              return;
            Uri url = serviceConnectionProperties.URL;      // Will be the URL to the Feature Service.
            string user = serviceConnectionProperties.User;     // The username property will only be
        // populated for feature service hosted
        // on non-federated ArcGIS Server.
            string password = serviceConnectionProperties.Password; // Will always be empty.
    Requirements
