ArcGIS.Core.Data Namespace / Datastore Class
Properties Methods
    Datastore Class Members
    The following tables list the members exposed by Datastore.
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Top
    Public Methods
     NameDescription
    Public Method Gets a value indicating whether this datastore supports datastore properties.
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the connection string associated with the currently opened data store (e.g., an enterprise geodatabase). This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the Connector associated with the currently opened data store. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the datastore properties of the datastore.
    Public Method Gets the path to the currently opened data store (e.g., an enterprise geodatabase .sde connection file). This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the gateway to access information about the SQL syntax and other functionality supported by this Datastore. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Determines whether the currently opened data store (e.g., an enterprise geodatabase) has any pending edits which have not been saved. This method must be called on the MCT. Use QueuedTask.Run.
    Top
