ArcGIS.Core.Data Namespace / Datastore Class / AreDatastorePropertiesSupported Method
Example
    Gets a value indicating whether this datastore supports datastore properties.
    Syntax
    Public Function AreDatastorePropertiesSupported() As Boolean
    public bool AreDatastorePropertiesSupported()
    Return Value
    true if this datastore supports datastore properties. false otherwise.
    Example
    Get datastore or workspace properties
      // Must be called within QueuedTask.Run
      void GetDatastoreProperties(Datastore geodatabase)
        // Check if a data store supports datastore properties
        bool areDatastorePropertiesSupported = geodatabase.AreDatastorePropertiesSupported();
        if (areDatastorePropertiesSupported)
          DatastoreProperties datastoreProperties = geodatabase.GetDatastoreProperties();
          // Supports 64-bit integer field
          bool supportsBigInteger = datastoreProperties.SupportsBigInteger;
          // Supports pagination
          bool supportsQueryPagination = datastoreProperties.SupportsQueryPagination;
          // Supports datastore edit
          bool canEdit = datastoreProperties.CanEdit;
          // Supports 64-bit Object ID
          bool supportsBigObjectId = datastoreProperties.SupportsBigObjectID;
          // Supports DateOnly field
          bool supportsDateOnly = datastoreProperties.SupportsDateOnly;
          // Supports TimeOnly field
          bool supportsTimeOnly = datastoreProperties.SupportsTimeOnly;
          // Supports TimestampOffset field
          bool supportsTimestampOffset = datastoreProperties.SupportsTimestampOffset;
    Requirements
    ArcGIS Pro version: 3.3 or higher.
