Public Function GetDatastoreProperties() As DatastoreProperties
public DatastoreProperties GetDatastoreProperties()
Return Value
The DatastoreProperties for this datastore.
| Exception | Description |
| System.InvalidOperationException | This datastore does not support datastore properties. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
// Must be called within QueuedTask.Run
void GetDatastoreProperties(Datastore geodatabase)
// Check if a data store supports datastore properties
bool areDatastorePropertiesSupported = geodatabase.AreDatastorePropertiesSupported();
if (areDatastorePropertiesSupported)
DatastoreProperties datastoreProperties = geodatabase.GetDatastoreProperties();
// Supports 64-bit integer field
bool supportsBigInteger = datastoreProperties.SupportsBigInteger;
// Supports pagination
bool supportsQueryPagination = datastoreProperties.SupportsQueryPagination;
// Supports datastore edit
bool canEdit = datastoreProperties.CanEdit;
// Supports 64-bit Object ID
bool supportsBigObjectId = datastoreProperties.SupportsBigObjectID;
// Supports DateOnly field
bool supportsDateOnly = datastoreProperties.SupportsDateOnly;
// Supports TimeOnly field
bool supportsTimeOnly = datastoreProperties.SupportsTimeOnly;
// Supports TimestampOffset field
bool supportsTimestampOffset = datastoreProperties.SupportsTimestampOffset;
