ArcGIS.Core.Data Namespace / Geodatabase Class / Geodatabase Constructor / Geodatabase Constructor(DatabaseConnectionProperties)
The properties used to connect to an enterprise geodatabase.
Example
    Opens an enterprise geodatabase with the specified connection properties. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    databaseConnectionProperties
    Exceptions
    ExceptionDescription
    The information used to connect to the geodatabase is invalid.
    A geodatabase-related exception has occurred.
    This object must be created within the lambda or delegate passed to QueuedTask.Run, or on a compatible STA thread.
    Example
    Opening an Enterprise Geodatabase using connection properties
      await QueuedTask.Run(() =>
        // Opening a Non-Versioned SQL Server instance.
        DatabaseConnectionProperties connectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
          AuthenticationMode = AuthenticationMode.DBMS,
          // Where testMachine is the machine where the instance is running and testInstance is the name of the SqlServer instance.
          Instance = @"testMachine\testInstance",
          // Provided that a database called LocalGovernment has been created on the testInstance and geodatabase has been enabled on the database.
          Database = "LocalGovernment",
          // Provided that a login called gdb has been created and corresponding schema has been created with the required permissions.
          User = "gdb",
          Password = "password",
          Version = "dbo.DEFAULT"
        using (Geodatabase geodatabase = new Geodatabase(connectionProperties))
          // Use the geodatabase
    Requirements
