ArcGIS.Desktop.Mapping Namespace / Layer Class / ReplaceDataSource Method
"An ArcGIS.Core.Data.Dataset"
    ReplaceDataSource Method (Layer)
    Replace the layer's data source. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub ReplaceDataSource( _
       ByVal dataset As Dataset _
    public void ReplaceDataSource(
       Dataset dataset
    Parameters
    dataset
    Exceptions
    ExceptionDescription
    Requirements
