ArcGIS.Desktop.Mapping.Controls Namespace / TransformationInfo Class / SpatialFilter Property
    SpatialFilter Property (TransformationInfo)
    Gets and sets the spatial filter. If specified, the SpatialFilter will be used to filter the available transformations for the given source and target spatial reference (which can initially not be defined).
    Syntax
    Public Property SpatialFilter As Envelope
    public Envelope SpatialFilter {get; set;}
    Remarks
    This is optional. The spatial filter can be defined in any spatial reference. It will be projected to the source spatial reference if needed. This property will override any SpatialFilter defined on the TransformationsControlProperties object. If no spatial filter is set on both the TransformationInfo object and the TransformationsControlProperties object, all the possible transformations for a given source and target coordinate system pair will be returned.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
