Public Overloads Shared Function CreateAngularUnit( _ ByVal unitWkt As String _ ) As AngularUnit
public static AngularUnit CreateAngularUnit( string unitWkt )
Parameters
- unitWkt
- The well-known text.
Return Value
An AngularUnit.
// custom unit - 3 radians per unit
var myAngularUnit = AngularUnit.CreateAngularUnit("myCustomAngularUnit", 3);
string Name = myAngularUnit.Name; // myCustomAngularUnit
double Factor = myAngularUnit.ConversionFactor; // 3
int Code = myAngularUnit.FactoryCode; // 0 because it is a custom angular unit
double radiansUnit = myAngularUnit.RadiansPerUnit; // 3
// convert 10 degrees to my unit
double converted = AngularUnit.Degrees.ConvertTo(10, myAngularUnit);
// convert it back to degrees
converted = myAngularUnit.ConvertTo(converted, AngularUnit.Degrees);
// convert 1 radian into my angular units
converted = myAngularUnit.ConvertFromRadians(1);
// get the wkt
string wkt = myAngularUnit.Wkt;
// create an angular unit from this wkt
var anotherAngularUnit = AngularUnit.CreateAngularUnit(wkt);
// anotherAngularUnit.ConversionFactor = 3
// anotherAngularUnit.FactoryCode = 0
// anotherAngularUnit.RadiansPerUnit = 3
