ArcGIS.Core.Data.Raster Namespace / PixelBlock Class / GetPixelData Method
Index of a plane from this pixel block
Flag that indicates whether to get the array of pixels by reference (false) or value (true).
Example
    GetPixelData Method
    Gets a 2-dimensional array of pixels from this pixel block based on the given plane. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetPixelData( _
       ByVal plane As Integer, _
       ByVal makeCopy As Boolean _
    ) As Array
    public Array GetPixelData(
       int plane,
       bool makeCopy
    Parameters
    plane
    makeCopy
    Return Value
    An array of pixels from this pixel block based on the given plane.
    Example
    Process pixels using a pixel block
    await QueuedTask.Run(() =>
      // Read pixel values from the raster dataset into the pixel block starting from the given top left corner.
      raster.Read(0, 0, currentPixelBlock);
      // For each plane (band) in the pixel block
      for (int plane = 0; plane < currentPixelBlock.GetPlaneCount(); plane++)
        // Get a copy of the array of pixels from the pixel block corresponding to the current plane.
        Array sourcePixels = currentPixelBlock.GetPixelData(plane, true);
        // Get the height and width of the pixel block.
        int pBHeight = currentPixelBlock.GetHeight();
        int pBWidth = currentPixelBlock.GetWidth();
        // Iterate through the pixels in the array.
        for (int i = 0; i < pBHeight; i++)
          for (int j = 0; j < pBWidth; j++)
            // Get the NoData mask value to see if the pixel is a valid pixel.
            if (Convert.ToByte(currentPixelBlock.GetNoDataMaskValue(plane, j, i)) == 1)
              // Get the pixel value from the array and process it (add 5 to the value).
              // Note: This is assuming the pixel type is Unisigned 8bit.
              int pixelValue = Convert.ToInt16(sourcePixels.GetValue(j, i)) + 5;
              // Make sure the pixel value does not go above the range of the pixel type.
              pixelValue = pixelValue > 254 ? 254 : pixelValue;
              // Set the new pixel value to the array.
              sourcePixels.SetValue(Convert.ToByte(pixelValue), j, i);
        // Set the modified array of pixels back to the pixel block.
        currentPixelBlock.SetPixelData(plane, sourcePixels);
      // Write the pixel block to the raster dataset starting from the given top left corner.
      raster.Write(0, 0, currentPixelBlock);
    Requirements
