Return Value
An integer representing the number of planes in this pixel block.
await QueuedTask.Run(() => { // Read pixel values from the raster dataset into the pixel block starting from the given top left corner. raster.Read(0, 0, currentPixelBlock); // For each plane (band) in the pixel block for (int plane = 0; plane < currentPixelBlock.GetPlaneCount(); plane++) { // Get a copy of the array of pixels from the pixel block corresponding to the current plane. Array sourcePixels = currentPixelBlock.GetPixelData(plane, true); // Get the height and width of the pixel block. int pBHeight = currentPixelBlock.GetHeight(); int pBWidth = currentPixelBlock.GetWidth(); // Iterate through the pixels in the array. for (int i = 0; i < pBHeight; i++) { for (int j = 0; j < pBWidth; j++) { // Get the NoData mask value to see if the pixel is a valid pixel. if (Convert.ToByte(currentPixelBlock.GetNoDataMaskValue(plane, j, i)) == 1) { // Get the pixel value from the array and process it (add 5 to the value). // Note: This is assuming the pixel type is Unisigned 8bit. int pixelValue = Convert.ToInt16(sourcePixels.GetValue(j, i)) + 5; // Make sure the pixel value does not go above the range of the pixel type. pixelValue = pixelValue > 254 ? 254 : pixelValue; // Set the new pixel value to the array. // Note: This is assuming the pixel type is Unisigned 8bit. sourcePixels.SetValue(Convert.ToByte(pixelValue), j, i); } } } // Set the modified array of pixels back to the pixel block. currentPixelBlock.SetPixelData(plane, sourcePixels); } // Write the pixel block to the raster dataset starting from the given top left corner. raster.Write(0, 0, currentPixelBlock); });
