ArcGIS.Core.Data.Raster Namespace / PixelBlock Class / GetValue Method
Index of a plane from this pixel block
X offset in the given plane
Y offset in given plane
    GetValue Method (PixelBlock)
    Gets the pixel value for the given plane, column and row from this pixel block. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetValue( _
       ByVal plane As Integer, _
       ByVal x As Integer, _
       ByVal y As Integer _
    ) As Object
    public object GetValue(
       int plane,
       int x,
       int y
    Parameters
    plane
    x
    y
    Return Value
    An object representing the pixel value for the given pixel.
    Requirements
