ArcGIS.Core.Data.Raster Namespace / PixelBlock Class / HasNoData Method
Index of a plane from this pixel block
    HasNoData Method
    Gets a value indicating whether the given plane from this pixel block has any NoData pixels. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function HasNoData( _
       ByVal plane As Integer _
    ) As Boolean
    public bool HasNoData(
       int plane
    Parameters
    plane
    Return Value
    A boolean value that is true if this plane has any NoData pixels; otherwise, false.
    Requirements
