Parameters
- format
- Format to save the raster to.
Return Value
A boolean value that is true if this raster can be saved to the given format; otherwise, false.
Storage properties such as tile size, compression etc. can be specified using the optional RasterStorageDef parameter. These parameters only apply to certain output raster formats and ArcGIS.Core.Data.Datastores. If parameters are not supported by the the output raster format or ArcGIS.Core.Data.Datastore, they are ignored.
The format strings used for the supported formats are below. The strings are case sensitive.
| Format Name | Format String |
| Imagine | "IMAGINE Image" |
| TIFF | "TIFF" |
| GRID | "GRID" |
| JPEG | "JPG" |
| JP2000 | "JP2" |
| BMP | "BMP" |
| PNG | "PNG" |
| GIF | "GIF" |
| PCI Raster | "PIX" |
| X11 Pixmap | "XPM" |
| PCRaster | "MAP" |
| Memory Raster | "MEM" |
| HDF4 | "HDF4" |
| BIL | "BIL" |
| BIP | "BIP" |
| BSQ | "BSQ" |
| Idrisi Raster Format | "RST" |
| ENVI Raster Format | "ENVI" |
| Geodatabase Raster | "GDB" |
