ArcGIS.Core.Data.Raster Namespace / Raster Class / GetPixelValue Method
Index of a band from this raster
Column from the given band
Row from the given band
    Gets the pixel value for the given band, row and column from this raster. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetPixelValue( _
       ByVal band As Integer, _
       ByVal column As Integer, _
       ByVal row As Integer _
    ) As Object
    public object GetPixelValue(
       int band,
       int column,
       int row
    Parameters
    band
    column
    row
    Return Value
    An object representing the pixel value for the given pixel.
    Requirements
