Public ReadOnly Property Current As PixelBlock
public PixelBlock Current {get;}
await QueuedTask.Run(() => { // Create a full raster from the raster dataset. ArcGIS.Core.Data.Raster.Raster raster = rasterDataset.CreateFullRaster(); // Calculate size of pixel blocks to process. Use 1000 or height/width of the raster, whichever is smaller. var height = raster.GetHeight(); var width = raster.GetWidth(); int pixelBlockHeight = height > 1000 ? 1000 : height; int pixelBlockWidth = width > 1000 ? 1000 : width; // Create the raster cursor using the height and width calculated. RasterCursor rasterCursor = raster.CreateCursor(pixelBlockWidth, pixelBlockHeight); // Use a do-while loop to iterate through the pixel blocks of the raster using the raster cursor. do { // Get the current pixel block from the cursor. using (PixelBlock currentPixelBlock = rasterCursor.Current) { // Do something with the pixel block... } // Once you are done, move to the next pixel block. } while (rasterCursor.MoveNext()); });
