ArcGIS.Core.Data.Raster Namespace / RasterDataset Class / CreateRaster Method
A set of band indices to use to create the Raster. For example, [0,1,2].
    CreateRaster Method
    Creates a Raster that has the same properties and the given list of bands from this raster dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CreateRaster( _
       ByVal bandIDs As IEnumerable(Of Integer) _
    ) As Raster
    public Raster CreateRaster(
       IEnumerable<int> bandIDs
    Parameters
    bandIDs
    Return Value
    The Raster created from this raster dataset.
    Requirements
