ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / GeodeticMove Method
The points that are to be moved.
The spatial reference of the points.
The distance by which the points will be moved.
The unit of the distance property.
The azimuth angle in radians of the direction for the points.
The type of curve to follow when moving the points.
Example
    GeodeticMove Method (IGeometryEngine)
    Moves each point in the input array by the given distance. The function returns the number of points that has been moved. Points that are outside of the horizon will be discarded.
    Syntax
    Parameters
    points
    spatialReference
    distance
    distanceUnit
    azimuth
    curveType
    Return Value
    The number of points moved. Points outside of the horizon will be discarded.
    Exceptions
    ExceptionDescription
    Points is null or empty. Or spatialReference is null.
    The method is not implemented for GeometryBag.
    The spatial reference is an image coordinate system.
    Example
    Perform Geodetic Move on a set of MapPoints
      SpatialReference sr = SpatialReferences.WebMercator;
      var points = new[] { MapPointBuilderEx.CreateMapPoint(0, 0, sr) };
      double distance = 10;
      double azimuth = Math.PI / 2;
      var resultPoints = GeometryEngine.Instance.GeodeticMove(points, sr, distance, LinearUnit.Meters, azimuth, GeodeticCurveType.Geodesic);
      // resultPoints.First().X = 10
      // resultPoints.First().Y = 0
      // resultPoints.First().SpatialReference.Wkid = sr.Wkid
      // Change LinearUnit to Miles
      resultPoints = GeometryEngine.Instance.GeodeticMove(points, sr, distance, LinearUnit.Miles, azimuth, GeodeticCurveType.Geodesic);
      // resultPoints.First().X = 16093.44
      // Change curve type
      resultPoints = GeometryEngine.Instance.GeodeticMove(points, sr, distance, LinearUnit.Miles, azimuth, GeodeticCurveType.Loxodrome);
    Requirements
