Parameters
- geometry
- The input geometry.
Return Value
The calculated length in the same units as the geometry's spatial reference unit. If the geometry is empty, then zero is returned.
| Exception | Description |
| System.ArgumentNullException | Geometry is null. |
| System.NotImplementedException | The method is not implemented for GeometryBag or Multipatch. |
| System.InvalidOperationException | The geometry is not Z-Aware. |
| ArcGIS.Core.Geometry.Exceptions.OperationException | Cannot do 3D operations on curve segments. |
| ArcGIS.Core.Geometry.Exceptions.GeometryObjectException | Geometry is not a polyline or polygon. |
MapPoint c1 = MapPointBuilderEx.CreateMapPoint(1, 2, 3);
MapPoint c2 = MapPointBuilderEx.CreateMapPoint(4, 2, 4);
// line segment
LineSegment line = LineBuilderEx.CreateLineSegment(c1, c2);
double len = line.Length; // = 3
double len3D = line.Length3D; // = Math.Sqrt(10)
// polyline
Polyline p = PolylineBuilderEx.CreatePolyline(line);
double p_len = p.Length; // = len = 3
double p_len3D = p.Length3D; // = len3D = Math.Sqrt(10)
double ge_len = GeometryEngine.Instance.Length(p); // = p_len = len = 3
double ge_len3d = GeometryEngine.Instance.Length3D(p); // = p_len3D = len3D = Math.Sqrt(10)
