Function Offset( _ ByVal geometry As Geometry, _ ByVal distance As Double, _ ByVal offsetType As OffsetType, _ ByVal bevelRatio As Double _ ) As Geometry
Geometry Offset( Geometry geometry, double distance, OffsetType offsetType, double bevelRatio )
Parameters
- geometry
- The geometry to calculate offset for. MapPoint and Multipoint are not supported.
- distance
- The offset distance for the geometry.
- offsetType
- The offset type of the offset geometry.
- bevelRatio
- The ratio used to produce a bevel join instead of a miter join (used only when offsetType is miter).
Return Value
The offset geometry. If the input geometry is empty, then it is returned unchanged.
