ArcGIS.Core.Geometry Namespace / Coordinate3D Structure / Rotate Method
The angle defining the rotation.
The axis around which the Coordinate3D is rotated.
Example
    Rotate Method (Coordinate3D)
    Rotates the Coordinate3D around an axis defined by another Coordinate3D. The angle is in radians.
    Syntax
    Public Sub Rotate( _
       ByVal angle As Double, _
       ByVal axis As Coordinate3D _
    public void Rotate(
       double angle,
       Coordinate3D axis
    Parameters
    angle
    axis
    Remarks
    The Coordinate3D is rotated a given input angle measured in radians around the specified axis defined by the input Coordinate3D. To rotate a Coordinate3D in a given plane defined by two Coordinate3D, use the CrossProduct of those coordinates as the axis of rotation.
    Example
    Vector Operations
      // Easy 3D vectors
      Coordinate3D v = new Coordinate3D(0, 1, 0);
      // v.Magnitude = 1
      Coordinate3D other = new Coordinate3D(-1, 0, 0);
      // other.Magnitude = -1
      double dotProduct = v.DotProduct(other);      // dotProduct = 0
      Coordinate3D crossProduct = v.CrossProduct(other);
      // crossProduct.X = 0
      // crossProduct.Y = 0
      // crossProduct.Z = 1
      Coordinate3D addVector = v.AddCoordinate3D(other);
      // addVector.X = -1
      // addVector.Y = 1
      // addVector.Z = 0
      // Rotate around x-axis
      Coordinate3D w = v;
      w.Rotate(Math.PI, other);
      // w.X = 0
      // w.Y = -1
      // w.Z = 0
      w.Scale(0.5);
      // w.X = 0
      // w.Y = -0.5
      // w.Z = 0
      w.Scale(-4);
      // w.X = 0
      // ww.Y = 2
      // w.Z = 0
      // w.Magnitude = 2
      w.Move(3, 2, 0);
      // w.X = 3
      // w.Y = 4
      // w.Z = 0
      // w.Magnitude = 5
      Coordinate3D emptyVector = new Coordinate3D();
      // emptyVector = (0, 0, 0)
      emptyVector.SetEmpty();
      // emptyVector = (Nan, Nan, Nan)
      Coordinate3D c1 = new Coordinate3D(2, 3, 4);
      Coordinate3D c2 = new Coordinate3D(9, -1, 3);
      var result_add = c1 + c2;
      // result_add = (11, 2, 7)
      var result_sub = c1 - c2;
      // result_sub = (-7, 4, 1)
      var b = result_sub != result_add;
      // b = true
      result_add = emptyVector + c1;
      // result_add = (Nan, Nan, Nan)
      b = result_add == emptyVector;
      // b = true
    Requirements
