Item Create( string uri, ItemFactory.ItemType itemType )
Function Create( _ ByVal uri As String, _ Optional ByVal itemType As ItemFactory.ItemType _ ) As Item
Parameters
- uri
- itemType
// Add a folder connection to a project
Item folderToAdd = ItemFactory.Instance.Create(@"C:\Data\Oregon\Counties\Streets");
var project = Project.Current;
bool wasAdded = await QueuedTask.Run(() => project.AddItem(folderToAdd as IProjectItem));
// use wasAdded;
// Import a mxd
Item mxdToImport = ItemFactory.Instance.Create(@"C:\Projects\RegionalSurvey\LatestResults.mxd");
var addedMxd = await QueuedTask.Run(() => project.AddItem(mxdToImport as IProjectItem));
// Add map package
Item mapPackageToAdd = ItemFactory.Instance.Create(@"c:\Data\Map.mpkx");
var addedMapPackage = await QueuedTask.Run(() => project.AddItem(mapPackageToAdd as IProjectItem));
// Add an exported Pro map
Item proMapToAdd = ItemFactory.Instance.Create(@"C:\ExportedMaps\Election\Districts.mapx");
var addedMapProjectItem = await QueuedTask.Run(() => project.AddItem(proMapToAdd as IProjectItem));
Item mxdItem = ItemFactory.Instance.Create(@"C:\Projects\RegionalSurvey\LatestResults.mxd");
// use mxdItem;
// Creates an Item from an existing portal item base on its ID
string portalItemID = "9801f878ff4a22738dff3f039c43e395";
Item portalItem = ItemFactory.Instance.Create(portalItemID, ItemFactory.ItemType.PortalItem);
// use portalItem;
// Creates an Item from an existing portal folder base on its ID
string portalFolderID = "39c43e39f878f4a2279838dfff3f0015";
Item portalFolder = ItemFactory.Instance.Create(portalFolderID, ItemFactory.ItemType.PortalFolderItem);
// use portalFolder;
var itemFolder = ItemFactory.Instance.Create(@"d:\data");
// is the folder item already a favorite?
var fav = FavoritesManager.Current.GetFavorite(itemFolder);
if (fav == null)
if (FavoritesManager.Current.CanAddAsFavorite(itemFolder))
fav = FavoritesManager.Current.AddFavorite(itemFolder);
gdbPath = "@C:\\myDataFolder\\myData.gdb";
var itemGDB = ItemFactory.Instance.Create(gdbPath);
// is the item already a favorite?
var favorite = FavoritesManager.Current.GetFavorite(itemGDB);
// no; add it with IsAddedToAllNewProjects set to true
if (favorite != null)
if (FavoritesManager.Current.CanAddAsFavorite(itemGDB))
FavoritesManager.Current.InsertFavorite(itemGDB, 1, true);
var newItemFolder = ItemFactory.Instance.Create(@"d:\data");
var favorite = FavoritesManager.Current.GetFavorite(newItemFolder);
if (favorite.IsAddedToAllNewProjects)
FavoritesManager.Current.ClearIsAddedToAllNewProjects(favorite.Item);
else
FavoritesManager.Current.SetIsAddedToAllNewProjects(favorite.Item);
Item gdbItem = ItemFactory.Instance.Create(@"C:\projectAlpha\GDBs\regionFive.gdb");
gdbMetadataItem = gdbItem as IMetadata;
Item featureClassItem = ItemFactory.Instance.Create(@"C:\projectAlpha\GDBs\regionFive.gdb\SourceFeatureClass");
await QueuedTask.Run(() => metadataCopyFrom.CopyMetadataFromItem(featureClassItem));
Item featureClassWithMetadataItem = ItemFactory.Instance.Create(@"C:\projectBeta\GDBs\regionFive.gdb\SourceFeatureClass");
//Delete thumbnail content from item's metadata
featureClassWithMetadataItem.DeleteMetadataContent(MDDeleteContentOption.esriMDDeleteThumbnail);
var fgdcItem = ItemFactory.Instance.Create(@"C:\projectAlpha\GDBs\testData.gdb");
await QueuedTask.Run(() => fgdcItem.UpgradeMetadata(MDUpgradeOption.esriUpgradeFgdcCsdgm));
//Create a new GDB item and add it to the project
if (ItemFactory.Instance.Create(newGDDItemPath) is not IProjectItem newGDBItem)
// could not create the item
return;
var success = Project.Current.AddItem(newGDBItem);
//make the newly added GDB item the default
if (success)
Project.Current.SetDefaultGeoDatabasePath(newGDDItemPath);
//Now remove the old item
if (Project.Current.GetItems<Item>().FirstOrDefault(i => i.Path == oldGDBItemPath) is not IProjectItem oldGDBItem)
// could not find the item
return;
var removeSuccess = Project.Current.RemoveItem(oldGDBItem);
//Adding a folder connection
//Create the folder connection project item
var item = ItemFactory.Instance.Create(folderPath) as IProjectItem;
var folder = await QueuedTask.Run(() =>
Project.Current.AddItem(item) ? item as FolderConnectionProjectItem : null);
//Adding a Geodatabase:
//Create the File GDB project item
var item = ItemFactory.Instance.Create(gdbPath) as IProjectItem;
var newlyAddedGDB = Project.Current.AddItem(item) ? item as GDBProjectItem : null;
// Get the ItemCategories with which an item is associated
gdb = ItemFactory.Instance.Create(@"E:\CurrentProject\RegionalPolling\polldata.gdb");
List<ItemCategory> gdbItemCategories = gdb.ItemCategories;
// Use gdbItemCategories;
var templateFileName = "Layout.pagx";
// Get layout Template Path from the project's home folder and combine it with a file name
var projectPath = CoreModule.CurrentProject.HomeFolderPath;
var layoutTemplateFilePath = System.IO.Path.Combine(projectPath, templateFileName);
// Create a new layout project item with the layout file path
// Create an IProjectItem using a layout template pagx file
IProjectItem pagx = ItemFactory.Instance.Create(layoutTemplateFilePath) as IProjectItem;
// Add the IProjectItem to the current project
await QueuedTask.Run(() => project.AddItem(pagx));
//Create a layout project item from importing a pagx file
@"C:\Temp\Layout.pagx") as IProjectItem;
project.AddItem(pagx);
string pathToGeoPackage = @"C:\Data\Geopackage\flooding.gpkg";
//Create lists to hold the URIs of the layers and tables in the geopackage
var layerUris = new List<Uri>();
var tableUris = new List<Uri>();
//Create an item from the geopackage
var item = ItemFactory.Instance.Create(pathToGeoPackage, ItemFactory.ItemType.PathItem);
var children = item.GetItems();
//Collect the table and spatial data in the geopackage
foreach (var child in children)
var childPath = child.Path;
if (child.TypeID == "sqlite_table")
tableUris.Add(new Uri(childPath));
else
layerUris.Add(new Uri(childPath));
//Add the spatial data in the geopackage using the BulkLayerCreationParams
if (layerUris.Count > 0)
BulkLayerCreationParams bulklcp = new BulkLayerCreationParams(layerUris);
LayerFactory.Instance.CreateLayers(bulklcp, map);
// add the tables separately
foreach (var tableUri in tableUris)
StandaloneTableFactory.Instance.CreateStandaloneTable(tableUri, map);
UriBuilder searchURL = new UriBuilder(ArcGISPortalManager.Current.GetActivePortal().PortalUri)
Path = "sharing/rest/search"
string layers = "(type:\"Map Service\" OR type:\"Image Service\" OR type:\"Feature Service\" OR type:\"WMS\" OR type:\"KML\")";
//any public layer content
searchURL.Query = string.Format("q={0}&f=json", layers);
EsriHttpClient httpClient = new EsriHttpClient();
var searchResponse = httpClient.Get(searchURL.Uri.ToString());
dynamic resultItems = JObject.Parse(await searchResponse.Content.ReadAsStringAsync());
long numberOfTotalItems = resultItems.total.Value;
if (numberOfTotalItems == 0)
return;
List<dynamic> resultItemList = new List<dynamic>();
resultItemList.AddRange(resultItems.results);
//get the first result
dynamic item = resultItemList[0];
string itemID = item.id;
Item currentItem = ItemFactory.Instance.Create(itemID, ItemFactory.ItemType.PortalItem);
var mapView = MapView.Active;
if (mapView == null)
return;
//Create a LayerCreationParam
var layerParam = new LayerCreationParams(currentItem);
// if we have an item that can be turned into a layer
// add it to the map
if (LayerFactory.Instance.CanCreateLayerFrom(currentItem))
LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParam, mapView.Map);
var reportFilePath = @"c:\temp\Report.rptx";
Item reportToImport = ItemFactory.Instance.Create(reportFilePath);
Project.Current.AddItem(reportToImport as IProjectItem);
