ArcGIS.Desktop.Core Namespace / IItemFactory Interface
Methods
    IItemFactory Interface Members
    The following tables list the members exposed by IItemFactory.
    Public Methods
     NameDescription
     Method Gets if the dataset for the item can be retrieved.
     Method Gets if the definition for the item can be retrieved.
     Method Gets if the Knowledge Graph named object type for the item can be retrieved.
     Method Defines the factory create method all factories must implement.
     MethodGets the ArcGIS.Core.Data.Dataset associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
     MethodGets the ArcGIS.Core.Data.DatasetType for the item. If the dataset type cannot be determined, then ArcGIS.Core.Data.DatasetType.Unknown is returned.
     MethodGets the ArcGIS.Core.Data.Definition associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
     MethodGets the ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectType associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
     MethodOverloaded.
    Top
