ArcGIS.Desktop.Core Namespace / IItemFactory Interface / GetKnowledgeGraphNamedObjectType Method
The item to check.
    GetKnowledgeGraphNamedObjectType Method (IItemFactory)
    Gets the ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectType associated with the item corresponding to Item.Path. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    KnowledgeGraphNamedObjectType GetKnowledgeGraphNamedObjectType(
       Item item
    Function GetKnowledgeGraphNamedObjectType( _
       ByVal item As Item _
    ) As KnowledgeGraphNamedObjectType
    Parameters
    item
    The item to check.
    Return Value
    A specific ArcGIS.Core.Data.Knowledge.KnowledgeGraphNamedObjectType (e.g., ArcGIS.Core.Data.Knowledge.KnowledgeGraphEntityType) associated with the item. A NotSupportedException will be thrown if the named object type cannot be determined for the item. Use CanGetKnowledgeGraphNamedObjectType to determine if the named object type can be retrieved before calling this.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    The named object type cannot be determined for this item. Check CanGetKnowledgeGraphNamedObjectType prior to calling this.
    item is null.
    Requirements
    ArcGIS Pro version: 3.5 or higher.
