ArcGIS.Core.Data.DDL Namespace / AttributeIndexDescription Class / AttributeIndexDescription Constructor / AttributeIndexDescription Constructor(Index,TableDescription)
The attribute ArcGIS.Core.Data.Index that the description object is representing.
The description object representing the ArcGIS.Core.Data.Table that will hold the attribute index.
Example
    Creates a description object of the attribute ArcGIS.Core.Data.Index.
    Syntax
    Public Function New( _
       ByVal attributeIndex As Index, _
       ByVal tableDescription As TableDescription _
    public AttributeIndexDescription(
       Index attributeIndex,
       TableDescription tableDescription
    Parameters
    attributeIndex
    tableDescription
    Exceptions
    ExceptionDescription
    The list of field names is invalid.
    Example
    Creating a table with index from scratch
      // Must be called within QueuedTask.Run
      void CreatingTableWithIndex(SchemaBuilder schemaBuilder)
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 50);
        FieldDescription addressFieldDescription = FieldDescription.CreateStringField("Address", 200);
        // Creating a feature class, 'Buildings' with two fields
        TableDescription tableDescription = new TableDescription("Buildings",
          new List<FieldDescription>() { nameFieldDescription, addressFieldDescription });
        // Enqueue DDL operation to create a table
        TableToken tableToken = schemaBuilder.Create(tableDescription);
        // Creating an attribute index named as 'Idx'
        AttributeIndexDescription attributeIndexDescription = new AttributeIndexDescription("Idx", new TableDescription(tableToken),
          new List<string> { nameFieldDescription.Name, addressFieldDescription.Name });
        // Enqueue DDL operation to create an attribute index
        schemaBuilder.Create(attributeIndexDescription);
        // Execute build indexes operation
        bool isBuildSuccess = schemaBuilder.Build();
    Removing attribute index
      void RemoveAttributeIndex(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition, string attributeIndexName)
        // Find a index to be removed
        ArcGIS.Core.Data.Index indexToRemove = featureClassDefinition.GetIndexes().First(f => f.GetName().Equals(attributeIndexName));
        // Index description of the index to be removed
        AttributeIndexDescription indexDescriptionToRemove = new AttributeIndexDescription(indexToRemove, new TableDescription(featureClassDefinition));
        // Enqueue the DDL operation to remove index
        schemaBuilder.Delete(indexDescriptionToRemove);
        // Execute the delete index operation
        bool isDeleteIndexSuccess = schemaBuilder.Build();
    Adding indexes in pre-existing dataset
      void AddingIndexes(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
        // Field names to add in the attribute index
        string fieldName = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Name")).Name;
        string fieldAddress = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Address")).Name;
        // Creating an attribute index with index name 'Idx' and two participating fields' name
          new TableDescription(featureClassDefinition), new List<string> { fieldName, fieldAddress });
        // Enqueue DDL operation for an attribute index creation
        // Creating the spatial index
        SpatialIndexDescription spatialIndexDescription = new SpatialIndexDescription(new FeatureClassDescription(featureClassDefinition));
        // Enqueue DDL operation for the spatial index creation
        schemaBuilder.Create(spatialIndexDescription);
        if (!isBuildSuccess)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
          // Iterate and handle errors
    Requirements
    ArcGIS Pro version: 3.1 or higher.
