ArcGIS.Core.Arcade Namespace / ArcadeEvaluationResult Class / CastTo Method
    CastTo Method
    Convert the result of the expression to the given type. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CastTo( _
       ByVal returnType As ExpressionReturnType _
    ) As Object
    Parameters
    returnType
    Return Value
    The converted value of the arcade expression.
    Exceptions
    ExceptionDescription
    Exception thrown when there has been an underlying exception from the evaluator
    Requirements
    ArcGIS Pro version: 3.2 or higher.
