ArcGIS.Desktop.Mapping Namespace / IColorFactory Interface / ConstructColorRamp Method / ConstructColorRamp(ColorRampAlgorithm,CIMColor,CIMColor) Method
ColorRampAlgorithm
The from color
The to color
    Construct a color ramp using the specified algorithm. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function ConstructColorRamp( _
       ByVal algorithm As ColorRampAlgorithm, _
       ByVal fromColor As CIMColor, _
       ByVal toColor As CIMColor _
    ) As CIMColorRamp
    Parameters
    algorithm
    ColorRampAlgorithm
    fromColor
    The from color
    toColor
    The to color
    Return Value
    CIMColorRamp
    Exceptions
    ExceptionDescription
    fromColor
    toColor
    Remarks
    From and to colors are ignored for ColorRampAlgorithm.Fixed. For ColorRampAlgorithm.RandomHSV the fromColor acts as the minimum, the toColor acts as the maximum. From and to colors are converted to HSV.
    Requirements
