ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructMarker Method / ConstructMarker(CIMColor,Double,SimpleMarkerStyle) Method
ArcGIS.Core.CIM.CIMColor
The size of the marker to construct.
SimpleMarkerStyle
Example
    Constructs a marker of specific color, size and style. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Overloads Function ConstructMarker( _
       ByVal color As CIMColor, _
       ByVal size As Double, _
       ByVal markerStyle As SimpleMarkerStyle _
    ) As CIMMarker
    Parameters
    color
    size
    markerStyle
    SimpleMarkerStyle
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Example
    How to construct a point symbol from a marker
      CIMMarker marker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.GreenRGB, 8.0, SimpleMarkerStyle.Pushpin);
      CIMPointSymbol pointSymbolFromMarker = SymbolFactory.Instance.ConstructPointSymbol(marker);
    How to construct a multilayer line symbol with circle markers on the line ends
      await QueuedTask.Run(() =>
        var lineStrokeRed = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 4.0);
        var markerCircle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Circle);
        markerCircle.MarkerPlacement = new CIMMarkerPlacementOnVertices()
          AngleToLine = true,
          PlaceOnEndPoints = true,
          Offset = 0
        var lineSymbolWithCircles = new CIMLineSymbol()
          SymbolLayers = new CIMSymbolLayer[2] { markerCircle, lineStrokeRed }
    How to construct a multilayer line symbol with an arrow head on the end
      var markerTriangle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Triangle);
      markerTriangle.Rotation = -90; // or -90
      markerTriangle.MarkerPlacement = new CIMMarkerPlacementOnLine() { AngleToLine = true, RelativeTo = PlacementOnLineRelativeTo.LineEnd };
      var lineSymbolWithArrow = new CIMLineSymbol()
        SymbolLayers = new CIMSymbolLayer[2] { markerTriangle,
                  SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 2)
    Dash line with two markers - Method I
    /// <summary>
    /// Create a line symbol with a dash and two markers.<br/>
    /// This line symbol comprises three symbol layers listed below:
    /// 1. A solid stroke that has dashes.
    /// 1. A circle marker.
    /// 1. A square marker.
    /// ![LineSymbolTwoMarkers](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/line-dash-two-markers.png)
    /// </summary>
      //Create a line symbol with a dash and two markers.
      //Note: Run withing QueuedTask
      CIMLineSymbol dash2MarkersLine = new CIMLineSymbol();
      var mySymbolLyrs = new CIMSymbolLayer[]
                  new CIMSolidStroke()
                      Color = ColorFactory.Instance.BlackRGB,
                      Enable = true,
                      ColorLocked = true,
                      CapStyle = LineCapStyle.Round,
                      JoinStyle = LineJoinStyle.Round,
                      LineStyle3D = Simple3DLineStyle.Strip,
                      MiterLimit = 10,
                      Width = 1,
                      CloseCaps3D = false,
                      Effects = new CIMGeometricEffect[]
                          new CIMGeometricEffectDashes()
                              CustomEndingOffset = 0,
                              DashTemplate = new double[] {20, 10, 20, 10},
                              LineDashEnding = LineDashEnding.HalfPattern,
                              OffsetAlongLine = 0,
                              ControlPointEnding = LineDashEnding.NoConstraint
                          new CIMGeometricEffectOffset()
                              Method = GeometricEffectOffsetMethod.Bevelled,
                              Offset = 0,
                              Option = GeometricEffectOffsetOption.Fast
                  CreateCircleMarkerPerSpecs(),
                  CreateSquareMarkerPerSpecs()
      dash2MarkersLine.SymbolLayers = mySymbolLyrs;
      static CIMMarker CreateCircleMarkerPerSpecs()
        var circleMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlackRGB, 5, SimpleMarkerStyle.Circle) as CIMVectorMarker;
        //Modifying the marker to align with line
        //First define "markerplacement"
        CIMMarkerPlacementAlongLineSameSize markerPlacement = new CIMMarkerPlacementAlongLineSameSize()
          AngleToLine = true,
          Offset = 0,
          Endings = PlacementEndings.Custom,
          OffsetAlongLine = 15,
          PlacementTemplate = new double[] { 60 }
        //assign the markerplacement to the marker
        circleMarker.MarkerPlacement = markerPlacement;
        return circleMarker;
      static CIMMarker CreateSquareMarkerPerSpecs()
        var squareMarker = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.BlueRGB, 5, SimpleMarkerStyle.Square) as CIMVectorMarker;
        CIMMarkerPlacementAlongLineSameSize markerPlacement2 = new CIMMarkerPlacementAlongLineSameSize()
          AngleToLine = true,
          OffsetAlongLine = 45,
          PlacementTemplate = new double[] { 60 },
        squareMarker.MarkerPlacement = markerPlacement2;
        return squareMarker;
    Dash line with two markers - Method II
    /// <summary>
    /// Create a line symbol with a dash and two markers. <br/>
    /// In this pattern of creating this symbol, a [CIMVectorMarker](https://doc.esri.com/en/arcgis-pro/latest/sdk/api-reference/#topic6176.html) object is created as a new [CIMSymbolLayer](https://doc.esri.com/en/arcgis-pro/sdk/api-reference/#topic5503.html).
    /// The circle and square markers created by [ContructMarker](https://doc.esri.com/en/arcgis-pro/latest/sdk/api-reference/#topic12350.html) method is then assigned to the [MarkerGraphics](https://doc.esri.com/en/arcgis-pro/sdk/api-reference/#topic6188.html) property of the CIMVectorMarker.
    /// When using this method, the CIMVectorMarker's [Frame](https://doc.esri.com/en/arcgis-pro/sdk/api-reference/#topic6187.html) property needs to be set to the [CIMMarker](https://doc.esri.com/en/arcgis-pro/sdk/api-reference/#topic3264.html) object's Frame.
    /// Similarly, the CIMVectorMarker's [Size](https://doc.esri.com/en/arcgis-pro/latest/sdk/api-reference/#topic3284.html) property needs to be set to the CIMMarker object's size.
    /// </summary>
      //default line symbol that will get modified.
      //circle marker to be used in our line symbol as a layer
      //Create the array of layers that make the new line symbol
      CIMSymbolLayer[] mySymbolLyrs =
                  new CIMSolidStroke() //dash line
                      Enable = true,
                      ColorLocked = true,
                      MiterLimit = 10,
                      Width = 1,
                              Offset = 0,
                  new CIMVectorMarker() //circle marker
                      MarkerGraphics = circleMarker.MarkerGraphics,
                      Frame = circleMarker.Frame, //need to match the CIMVector marker's frame to the circleMarker's frame.
                      Size = circleMarker.Size,    //need to match the CIMVector marker's size to the circleMarker's size.
                     MarkerPlacement = new CIMMarkerPlacementAlongLineSameSize()
                         AngleToLine = true,
                         Offset = 0,
                         PlacementTemplate = new double[] {60},
                  new CIMVectorMarker() //square marker
                     MarkerGraphics = squareMarker.MarkerGraphics,
                     Frame = squareMarker.Frame, //need to match the CIMVector marker's frame to the squareMarker frame.
                     Size = squareMarker.Size, //need to match the CIMVector marker's size to the squareMarker size.
                         AngleToLine = true,
    Requirements
