ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructMarker Method / ConstructMarker(Int32,String,String,Int32) Method
The index of the character from the font.
The font family name of the character marker to construct.
The font style name (Regular, Bold, Italic, etc.) of the character marker to construct.
The size of the marker to construct.
Example
    Constructs a character marker.
    Syntax
    Overloads Function ConstructMarker( _
       ByVal characterIndex As Integer, _
       ByVal fontFamily As String, _
       ByVal fontStyle As String, _
       ByVal size As Integer _
    ) As CIMMarker
    Parameters
    characterIndex
    fontFamily
    fontStyle
    size
    Return Value
    Example
    Markers placed at a 45 degree angle
    /// <summary>
    /// Create a line symbol with the markers placed at a 45 degree angle. <br/>
    /// ![LineSymbolAngleMarker](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/line-marker-angle.png)
    /// </summary>
      //Create a line symbol with the markers placed at a 45 degree angle.
      //Create a marker from the "|" character.  This is the marker that will be used to render the line layer.
      //Note: Run withing QueuedTask
      var lineMarker = SymbolFactory.Instance.ConstructMarker(124, "Agency FB", "Regular", 12);
      //Default line symbol which will be modified
      CIMLineSymbol lineSymbolWithMarkersAtAngle = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlackRGB, 2, SimpleLineStyle.Solid);
      //Modifying the marker to align with line
      //First define "markerplacement"
      CIMMarkerPlacementAlongLineSameSize markerPlacement = new CIMMarkerPlacementAlongLineSameSize()
        AngleToLine = true,
        PlacementTemplate = new double[] { 5 }
      //assign the markerplacement to the marker
      lineMarker.MarkerPlacement = markerPlacement;
      //angle the marker if needed
      lineMarker.Rotation = 45;
      //assign the marker as a layer to the line symbol
      lineSymbolWithMarkersAtAngle.SymbolLayers[0] = lineMarker;
    Point Symbol from a font
    /// <summary>
    /// Create a point symbol from a character in a font file
    /// ![PointSymbolFont](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/point-marker.png)
    /// </summary>
      //creating the marker from the Font selected
      var cimMarker = SymbolFactory.Instance.ConstructMarker(47, "Wingdings 3", "Regular", 12);
      CIMPointSymbol fontPointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
      //To apply the symbol to a point feature layer
      //var renderer = pointLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = fontPointSymbol.MakeSymbolReference();
      //pointLayer.SetRenderer(renderer);
    Requirements
