ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructMarker Method / ConstructMarker(Int32,String,String,Int32,CIMColor) Method
The index of the character from the font.
The font family name of the character marker to construct.
The font style name (Regular, Bold, Italic, etc.) of the character marker to construct.
The size of the marker to construct.
ArcGIS.Core.CIM.CIMColor
Example
    Constructs a character marker.
    Syntax
    Overloads Function ConstructMarker( _
       ByVal characterIndex As Integer, _
       ByVal fontFamily As String, _
       ByVal fontStyle As String, _
       ByVal size As Integer, _
       ByVal color As CIMColor _
    ) As CIMMarker
    Parameters
    characterIndex
    fontFamily
    fontStyle
    size
    color
    Return Value
    Example
    Modify a point symbol created from a character marker
      //create marker from the Font, char index,size,color
      await QueuedTask.Run(() =>
        var cimMarker = SymbolFactory.Instance.ConstructMarker(125, "Wingdings 3", "Regular", 6, ColorFactory.Instance.BlueRGB) as CIMCharacterMarker;
        var polygonMarker = cimMarker.Symbol;
        //modifying the polygon's outline and fill
        //This is the outline
        polygonMarker.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.GreenRGB, 2, SimpleLineStyle.Solid);
        //This is the fill
        polygonMarker.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.BlueRGB);
        //create a symbol from the marker
        //Note this overload of ConstructPointSymbol does not need to be run within QueuedTask.Run.
        var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
    Requirements
