CIMPointSymbol ConstructPointSymbol( CIMColor color )
Overloads Function ConstructPointSymbol( _ ByVal color As CIMColor _ ) As CIMPointSymbol
Parameters
- color
- ArcGIS.Core.CIM.CIMColor
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run |
await QueuedTask.Run(() =>
//The goal is to construct the CIMUniqueValueRenderer which will be applied to the feature layer.
// To do this, the following are the objects we need to set the renderer up with the fields and symbols.
// As a reference, this is the USCities dataset. Snippet will create a unique value renderer that applies
// specific symbols to all the cities in California and Alabama. The rest of the cities will use a default symbol.
// First create a "CIMUniqueValueClass" for the cities in Alabama.
List<CIMUniqueValue> listUniqueValuesAlabama = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "Alabama" } } };
CIMUniqueValueClass alabamaUniqueValueClass = new CIMUniqueValueClass
Editable = true,
Label = "Alabama",
Patch = PatchShape.Default,
Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
Visible = true,
Values = listUniqueValuesAlabama.ToArray()
// Create a "CIMUniqueValueClass" for the cities in California.
List<CIMUniqueValue> listUniqueValuescalifornia = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "California" } } };
CIMUniqueValueClass californiaUniqueValueClass = new CIMUniqueValueClass
Editable = true,
Label = "California",
Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
Visible = true,
Values = listUniqueValuescalifornia.ToArray()
//Create a list of the above two CIMUniqueValueClasses
List<CIMUniqueValueClass> listUniqueValueClasses = new List<CIMUniqueValueClass>
alabamaUniqueValueClass, californiaUniqueValueClass
//Create a list of CIMUniqueValueGroup
CIMUniqueValueGroup uvg = new CIMUniqueValueGroup
Classes = listUniqueValueClasses.ToArray(),
List<CIMUniqueValueGroup> listUniqueValueGroups = new List<CIMUniqueValueGroup> { uvg };
//Create the CIMUniqueValueRenderer
CIMUniqueValueRenderer uvr = new CIMUniqueValueRenderer
UseDefaultSymbol = true,
DefaultLabel = "all other values",
DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
Groups = listUniqueValueGroups.ToArray(),
Fields = new string[] { "STATE_NAME" }
//Set the feature layer's renderer.
featureLayer.SetRenderer(uvr);
//Place symbol in the center of the map
var extent = mapView.Extent;
var location = extent.Center;
//specify a symbol
var pt_symbol = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.GreenRGB);
//create a CIMGraphic
var graphic = new CIMPointGraphic()
Symbol = pt_symbol.MakeSymbolReference(),
Location = location //center of map
graphicsLayer.AddElement(graphic);
//Place a multipoint graphic using the mapview extent geometry
//Contract the extent
var polygonEnv = extent.Expand(-100000, -90000, false);
//create a polygon using the envelope
var polygon = PolygonBuilderEx.CreatePolygon(polygonEnv);
//Create MultipPoints from the polygon
var multiPoints = MultipointBuilderEx.CreateMultipoint(polygon);
//specify a symbol
var point_symbol = SymbolFactory.Instance.ConstructPointSymbol(
var graphic = new CIMMultipointGraphic
Symbol = point_symbol.MakeSymbolReference(),
Multipoint = multiPoints
//specify a symbol
graphicsLayer.AddElement(location, pt_symbol);
/// <summary> /// Renders a feature layer using graduated symbols and natural breaks to draw quantities. ///  /// </summary> { //Check feature layer name //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics"); if (featureLayer == null) { MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing"); } GraduatedSymbolsRendererDefinition gsDef = new GraduatedSymbolsRendererDefinition() { ClassificationField = "NumericFieldInFeatureLayer", //getting the first numeric field ClassificationMethod = ClassificationMethod.NaturalBreaks, SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(76, 230, 0)).MakeSymbolReference(), MinimumSymbolSize = 4, MaximumSymbolSize = 50, BreakCount = 5, ColorRamp = colorRamp, //getting a color ramp }; await QueuedTask.Run(() => { CIMClassBreaksRenderer renderer = (CIMClassBreaksRenderer)featureLayer.CreateRenderer(gsDef); featureLayer?.SetRenderer(renderer); }); }
