ConstructPointSymbol(CIMColor,Double,SimpleMarkerStyle) Method
Constructs a point symbol of specific color, size and style. This method must be called on the MCT. Use QueuedTask.Run.
How to add a style item to a style
//Create a new style item
//You can generate a swatch for a text symbols also.
CIMSymbol symbolToAdd = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
SymbolStyleItem styleItemToAdd = new SymbolStyleItem()
Symbol = symbolToAdd,
PatchHeight = 64,
PatchWidth = 64
styleProjectItem.AddItem(styleItemToAdd);
How to construct a point symbol of a specific color, size and shape
CIMPointSymbol starPointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 10.0, SimpleMarkerStyle.Star);
Create a Swatch for a given symbol
await QueuedTask.Run(() =>
CIMSymbol symbolForSwatch = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
var si = new SymbolStyleItem()
Symbol = symbolForSwatch,
PatchHeight = 64,
PatchWidth = 64
Convert Point Symbol to SVG
var mem_strm = await QueuedTask.Run(() =>
//Create a point symbol
var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.RedRGB, 24, SimpleMarkerStyle.RoundedSquare);
//Generate image returns a stream
return SymbolFactory.Instance.GenerateImage(
pointSymbol, OutputImageFormat.SVG, 2.0, true, 300, 100, 100,
ColorFactory.Instance.WhiteRGB);
//Set the memory stream position to the beginning
mem_strm.Seek(0, SeekOrigin.Begin);
//File path and name for saving the SVG file
var fileName = "RoundedSquareSymbol.svg";
string path_svg = System.IO.Path.Combine(System.IO.Path.GetTempPath() + fileName);
//Write the memory stream to the file
System.IO.File.WriteAllBytes(path_svg, mem_strm.ToArray());
//Note: to convert SVG to image format, use a 3rd party
//e.g. Aspose.SVG for .NET, for example convert SVG to PNG
//using (var svg_doc = new Aspose.Svg.SVGDocument(path_svg))
// string path_png = Path.Combine(Path.GetTempPath() + "RoundedSquareSymbol.png");
// using (var img_png = new Aspose.Svg.Rendering.Image.ImageDevice(
// new ImageRenderingOptions(ImageFormat.Png), path_png))
// svg_doc.RenderTo(img_png);
// //also: https://docs.aspose.com/imaging/net/convert-svg-to-png/
Convert Point Symbol to PNG
pointSymbol, OutputImageFormat.PNG, 2.0, true, 300, 100, 100,
//Write the stream to a bit map
var bitmapImage = new System.Windows.Media.Imaging.BitmapImage();
bitmapImage.BeginInit();
bitmapImage.StreamSource = mem_strm;
bitmapImage.CacheOption = System.Windows.Media.Imaging.BitmapCacheOption.OnLoad;
bitmapImage.EndInit();
bitmapImage.Freeze();
//Write the bit map out to a file
//File path and name for saving the PNG file
var fileName = "RoundedSquareSymbol.png";
string path_png = System.IO.Path.Combine(System.IO.Path.GetTempPath() + fileName);
BitmapEncoder encoder = new PngBitmapEncoder();
encoder.Frames.Add(BitmapFrame.Create(bitmapImage));
using (var fileStream = new System.IO.FileStream(
path_png, System.IO.FileMode.Create))
encoder.Save(fileStream);
Create layer with create-params
var flyrCreatnParam = new FeatureLayerCreationParams(new Uri(@"c:\data\world.gdb\cities"))
Name = "World Cities",
IsVisible = false,
MinimumScale = 1000000,
MaximumScale = 5000,
DefinitionQuery = new DefinitionQuery(whereClause: "Population > 100000", name: "More than 100k"),
RendererDefinition = new SimpleRendererDefinition()
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
var featureLayerWithParams = await QueuedTask.Run(() =>
LayerFactory.Instance.CreateLayer<FeatureLayer>(flyrCreatnParam, map));
Create a new SubTypeGroupLayer
var subtypeGroupLayerCreateParam = new SubtypeGroupLayerCreationParams
(new Uri(@"c:\data\SubtypeAndDomain.gdb\Fittings"));
// Define Subtype layers
var rendererDefn1 = new UniqueValueRendererDefinition(new List<string> { "type" });
var renderDefn2 = new SimpleRendererDefinition()
subtypeGroupLayerCreateParam.SubtypeLayers = new List<SubtypeFeatureLayerCreationParams>()
//define first subtype layer with unique value renderer
new SubtypeFeatureLayerCreationParams(new UniqueValueRendererDefinition(new List<string> { "type" }), 1),
//define second subtype layer with simple symbol renderer
new SubtypeFeatureLayerCreationParams(renderDefn2, 2)
// Define additional parameters
subtypeGroupLayerCreateParam.DefinitionQuery = new DefinitionQuery(whereClause: "Enabled = 1", name: "IsActive");
subtypeGroupLayerCreateParam.IsVisible = true;
subtypeGroupLayerCreateParam.MinimumScale = 50000;
SubtypeGroupLayer subtypeGroupLayer2 = await QueuedTask.Run(() =>
LayerFactory.Instance.CreateLayer<SubtypeGroupLayer>(subtypeGroupLayerCreateParam, map));
Set unique value renderer to the selected feature layer of the active map
//field to be used to retrieve unique values
var fields = new List<string> { "Type" };
//constructing a point symbol as a template symbol
CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Pushpin);
CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
//constructing renderer definition for unique value renderer
UniqueValueRendererDefinition uniqueValueRendererDef =
new UniqueValueRendererDefinition(fields, symbolPointTemplate);
//creating a unique value renderer
CIMUniqueValueRenderer uniqueValueRenderer = featureLayer.CreateRenderer(uniqueValueRendererDef) as CIMUniqueValueRenderer;
//setting the renderer to the feature layer
featureLayer.SetRenderer(uniqueValueRenderer);
Create an unclassed Renderer
string colorBrewerSchemesName = "ArcGIS Colors";
//Get the style project item that contains the color ramps
//Refer to the Initialize region for an example of how to get a style item
CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Diamond);
//defining an unclassed renderer with custom upper and lower stops
//all features with value >= 5,000,000 will be drawn with the upper color from the color ramp
//all features with value <= 50,000 will be drawn with the lower color from the color ramp
UnclassedColorsRendererDefinition unclassRndrDef = new UnclassedColorsRendererDefinition
("Population", symbolPointTemplate, colorRamp, "Highest", "Lowest", 5000000, 50000)
//drawing features with null values with a different symbol
ShowNullValues = true,
NullValueLabel = "Unknown"
// Create a point symbol for null values
CIMPointSymbol nullSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 16.0, SimpleMarkerStyle.Circle);
unclassRndrDef.NullValueSymbol = nullSym.MakeSymbolReference();
//Create the unclassed renderer using the definition
CIMClassBreaksRenderer cbRndr = featureLayer.CreateRenderer(unclassRndrDef) as CIMClassBreaksRenderer;
//Set the renderer to the feature layer
featureLayer.SetRenderer(cbRndr);
Create a Proportion Renderer with max and min symbol size capped
//Creating a point symbol to be used as a template symbol for the proportional renderer
CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
//minimum symbol size is capped to 4 point while the maximum symbol size is set to 50 point
//Creating a proportional renderer definition that uses the "Population" field
ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", symbolPointTemplate, 4, 50, true)
//setting upper and lower size stops to stop symbols growing or shrinking beyond those thresholds
UpperSizeStop = 5000000, //features with values >= 5,000,000 will be drawn with maximum symbol size
LowerSizeStop = 50000 //features with values <= 50,000 will be drawn with minimum symbol size
// Create a proportional renderer using the definition
CIMProportionalRenderer propRndr = featureLayer.CreateRenderer(prDef) as CIMProportionalRenderer;
// Set the renderer to the feature layer
featureLayer.SetRenderer(propRndr);
Create a True Proportion Renderer
//Defining proportional renderer where size of symbol will be same as its value in field used in the renderer.
ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", esriUnits.esriMeters, symbolPointTemplate, SymbolShapes.Square, ValueRepresentations.Radius);
//Create a Proportional renderer using the definition
Add the Most Recent Location To A Graphics Layer
// get the last location
var pt = DeviceLocationService.Instance.GetCurrentSnapshot()?.GetPositionAsMapPoint();
if (pt != null)
var ptSymbol = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(125, 125, 0), 10, SimpleMarkerStyle.Triangle);
//Add a graphic to the graphics layer
graphicsLayer.AddElement(pt, ptSymbol);
//unselect it
graphicsLayer.ClearSelection();
Graphic Overlay
// get the current MapView and point
var myextent = mapView.Extent;
var point = myextent.Center;
IDisposable _graphic = null;
// add point graphic to the overlay at the center of the mapView
_graphic = mapView.AddOverlay(point,
ColorFactory.Instance.RedRGB, 30.0, SimpleMarkerStyle.Star).MakeSymbolReference());
// update the overlay with new point graphic symbol
MessageBox.Show("Now to update the overlay...");
mapView.UpdateOverlay(_graphic, point, SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.BlueRGB, 20.0, SimpleMarkerStyle.Circle).MakeSymbolReference());
// clear the overlay display by disposing of the graphic
MessageBox.Show("Now to clear the overlay...");
_graphic.Dispose();
Bulk Graphics creation
//Point Feature layer to convert into graphics
var lyr = mapView?.Map?.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(s => s.ShapeType == esriGeometryType.esriGeometryPoint);
if (lyr == null)
return;
//Point symbol for graphics
var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(100, 255, 40), 10, SimpleMarkerStyle.Circle);
//Collection to hold the point graphics
var listGraphicElements = new List<CIMGraphic>();
//Iterate through each point feature in the feature layer
using (RowCursor rows = lyr.Search()) //execute
int i = 0;
while (rows.MoveNext())
using var feature = rows.Current as Feature;
//Create a point graphic for the feature
var crimePt = feature.GetShape() as MapPoint;
if (crimePt != null)
var cimGraphicElement = new CIMPointGraphic
Location = crimePt, //MapPoint
Symbol = pointSymbol.MakeSymbolReference()
//Add the point feature to the collection
listGraphicElements.Add(cimGraphicElement);
i++;
//Magic happens...Add all the features to the Graphics layer
graphicsLayer.AddElements(listGraphicElements);
Simple Renderer for a Point feature layer.
/// <summary>
/// Renders a Point feature layer using a single symbol.
/// </summary>
//Check feature layer name
//Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.ShapeType == esriGeometryType.esriGeometryPoint);
if (featureLayer == null)
MessageBox.Show("This renderer works with a point feature layer", "Data missing");
//Create a circle marker
var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 8, SimpleMarkerStyle.Circle);
//Get the layer's current renderer
CIMSimpleRenderer renderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
//Update the symbol of the current simple renderer
renderer.Symbol = pointSymbol.MakeSymbolReference();
//Update the feature layer renderer
featureLayer.SetRenderer(renderer);
Create a stream layer with a simple renderer
var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/LABus/StreamServer";
var uri = new Uri(url, UriKind.Absolute);
var createParams = new FeatureLayerCreationParams(uri)
12,
SimpleMarkerStyle.Pushpin).MakeSymbolReference()
streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(
createParams, map);
Setting a unique value renderer for latest observations
var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
IsVisible = false
createParams, map);
//Define the unique values by hand
var uvr = new CIMUniqueValueRenderer()
Fields = new string[] { "ACTYPE" },
UseDefaultSymbol = true,
DefaultLabel = "Others",
DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(185, 185, 185), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
var classes = new List<CIMUniqueValueClass>
//add in classes - one for ACTYPE of 727, one for DC 9
new CIMUniqueValueClass()
Values = new CIMUniqueValue[] {
new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
Visible = true,
Label = "Boeing 727",
ColorFactory.Instance.RedRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
Visible = true,
Label = "DC 9",
ColorFactory.Instance.GreenRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
//add the classes to a group
var groups = new List<CIMUniqueValueGroup>()
new CIMUniqueValueGroup() {
Classes = classes.ToArray()
//add the groups to the renderer
uvr.Groups = groups.ToArray();
//Apply the renderer (for current observations)
streamLayer.SetRenderer(uvr);
streamLayer.SetVisibility(true);//turn on the layer
Defining a unique value renderer definition
streamLayer = null;
//https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer
var uvrDef = new UniqueValueRendererDefinition()
ValueFields = new List<string> { "ACTYPE" },
.MakeSymbolReference(),
ValuesLimit = 5
//Note: CreateRenderer can only create value classes based on
//the current events it has received
streamLayer.SetRenderer(streamLayer.CreateRenderer(uvrDef));
Setting a unique value renderer for latest observations 2
//Define the classes by hand to avoid using CreateRenderer(...)
CIMUniqueValueClass uvcB727 = new CIMUniqueValueClass()
Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
Visible = true,
Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
CIMUniqueValueClass uvcD9 = new CIMUniqueValueClass()
Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
Visible = true,
Label = "DC 9",
Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(0, 255, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
//Assign the classes to a group
CIMUniqueValueGroup uvGrp = new CIMUniqueValueGroup()
Classes = new CIMUniqueValueClass[] { uvcB727, uvcD9 }
//assign the group to the renderer
var UVrndr = new CIMUniqueValueRenderer()
Groups = new CIMUniqueValueGroup[] { uvGrp },
//set the renderer. Depending on the current events received, the
//layer may or may not have events for each of the specified
//unique value classes
streamLayer.SetRenderer(UVrndr);
Setting a unique value renderer for previous observations
//The layer must be track aware and spatial
if (streamLayer.TrackType != TrackType.Spatial)
// not track aware and spatial
//Define unique value classes same as we do for current observations
//or use "CreateRenderer(...)" to assign them automatically
CIMUniqueValueClass uvcB727Prev = new CIMUniqueValueClass()
Visible = true,
CIMColor.CreateRGBColor(255, 0, 0), 4, SimpleMarkerStyle.Hexagon)
CIMUniqueValueClass uvcD9Prev = new CIMUniqueValueClass()
Visible = true,
Label = "DC 9",
CIMColor.CreateRGBColor(0, 255, 0), 4, SimpleMarkerStyle.Hexagon)
CIMUniqueValueGroup uvGrpPrev = new CIMUniqueValueGroup()
Classes = new CIMUniqueValueClass[] { uvcB727Prev, uvcD9Prev }
Groups = new CIMUniqueValueGroup[] { uvGrpPrev },
CIMColor.CreateRGBColor(185, 185, 185), 4, SimpleMarkerStyle.Hexagon)
streamLayer.SetRenderer(UVrndr, FeatureRendererTarget.PreviousObservations);
Custom fill and outline
/// <summary>
/// Creates a point symbol with custom fill and outline
/// </summary>
//Note: Run withing QueuedTask
var circlePtCustomFileOutlineSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB, 6, SimpleMarkerStyle.Circle);
//Modifying this point symbol with the attributes we want.
//getting the marker that is used to render the symbol
var marker = circlePtCustomFileOutlineSymbol.SymbolLayers[0] as CIMVectorMarker;
//Getting the polygon symbol layers components in the marker
var polySymbol = marker.MarkerGraphics[0].Symbol as CIMPolygonSymbol;
//modifying the polygon's outline and width per requirements
polySymbol.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 2, SimpleLineStyle.Solid); //This is the outline
polySymbol.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.GreenRGB); //This is the fill
//To apply the symbol to a point feature layer
//var renderer = pointLayer.GetRenderer() as CIMSimpleRenderer;
//renderer.Symbol = circlePtCustomFileOutlineSymbol.MakeSymbolReference();
//pointLayer.SetRenderer(renderer);
